nehasharma
is anybody facing any wifi issues with the desire s......it anybody getting dropped wifi signals while holding the phone is a specific position......if yes then how bad is the wifi signal drop?
I've heard about the problem, but not come across it myself.
I got mine on Sunday and have no wifi drop at all, portrait or landscape. In fact, the wifi stability is a big improvement on my Legend. If a number of people are posting about it, there must be a batch of faulty handsets out there, but it doesn't seem to be an issue in my device.
when you use the wifi on you desire s, are you near of far away from you router?
As i said above,i have no problems whatsoever with wifi signal so it cant be a handset problem,unless my desire s is a one off.
Ive just tested it and the signal stays the same (full),wether im in the house,garden or out in the street.
I use a netgear DG834GT router on o2.
), but this never happens when I am typing in portrait mode as I only cover the bottom part of the phone. Maybe for guys with bigger hands, this is the issue...
