Help WIFI Issues
digitrev
I'm having problems with the Optimus One's wifi capabilities.
Here's the situation:
  • Just did a factory reset, so it's not anything I've done
  • Wi-Fi: checked
  • Network notification: checked
  • Wi-Fi sleep policy: Never
  • Bluetooth: on, but not connected
  • 3G Data: blocked by the carrier (my choice, since I'm cheap)
  • Router is a D-Link DIR-655
  • Router has about 10 other wireless devices that work properly
Here's what happens when I try to connect:
  • Security is WEP and signal strength is excellent.
  • Password is hex digits.
  • Hit connect.
  • "Obtaining IP address..."
  • Wait a few seconds (I'm patient)
  • Then the network says "Remembered, secured with WEP"
  • Then the Wi-Fi starts "Scanning..."
  • Now the network says "Disabled, secured with WEP"
  • Click on it again, select "Connect"
  • Go back to "Obtaining IP address..."
  • Repeat ad nauseum
Why won't it work?
