Help wifi issues
guttyla
I periodically lose my connection and can't reconnect. Other devices can connect, but not the Bionic. I've tried turning it off/on...both wifi and the Bionic, I've tried putting it in airplane mode too but can't reconnect. The only thing that works is unplugging my router and plugging it back in...it's a nuisance.
Any suggestions?
wait - you say other devices can reconnect - that means all devices are losing signal but only the BIONIC cannot reconnect?
I wonder if it is a timeout value? Hmmm, I'm off to explore something else...
known issue with android devices. the only way i fixed this with my samsung captivate was to do a hard reset. there's also a wifi fixer in the market. try that before anything.
  • Like
Reactions: ecb
I couldn't get mine to work on my DX for months, then I got the bionic and it did the same thing. Found out that this worked for me
Menu > Settings > Wireless & networks > make sure wi-fi is on > scroll to the bottom and select Manage networks > Manage networks options > forget all networks. After doing that, I signed back into my network and it works fine. I connect to a lot of wireless networks and one of them had things all messed up.
I hope it works for you also.
  • Like
Reactions: ecb
Sounds similar to an issue I'm having. I noticed from the begining that my Wifi Speeds (using the Speedtest app) were horrible when compared to my iPhone. I didn't pay that much attention because it was still decent speed for a phone. However, when I noticed that WiFi was one of my biggest battery drainers I started digging a little deeper.
It seems like my Wifi connection is dropping when there are bursts of data. For example, if I use the speedtest app repeatedly (or use the speedtest tools on dslreport.com) I'll quickly get to a point where my data connection is hosed (the speedtest app will complain about losing network connectivity, web browser will indicate that there is no internet connection). It doesn't seem to completely drop the connection, but Wifi is definitly vey flakey with the combination of the Bionic and my network (which is nothing fancy, just using WPA2 for security)
I'll certainly try forgetting the network and then reentering the credentials (thanks for that tip) but if wifi is not rock solid, I can't see keeping a very expensive phone and then hoping the issue is fixed with a firmware upgrade.
I'll post back if I find anything that works
