Root Wifi Issues
jreink01
Android Expert
I have a triumph that is rooted and flashed with CM7. I am a driver and I have just noticed these issues. I often go to different McDonalds restaurants in the course of my day and I occasionally use wifi there. I will turn on wifi at the one McDonalds and have to open up a web page to accept there TOS. The wifi works fine. Then Ill be at another McDonalds and the phone connects with their wifi but when I open a google page, the previous one that I accepted with the TOS is still up. I try to back all the way out, but then when I press on the icon to open upa web page, that TOS page from the first McDonalds wifi still pops up. At the second McDonalds, it says unable to connect (I suspect because that first TOS page did not close. I will then reboot the phone and try to connect to the wifi at the second McDonalds and it works fine. I suspect that when I had that page up, using the back button does not close the page. How do I permanently close a web page (to the point where if I reopen the same page, it has to load again)? In the stock rom, there was a option to close the web page. In CM7, I do not se this option. How do you guys permanently close your web pages?? Thanks for your help..
Hit the 4 square menu button and click on windows and push the x beside the web page your on and then just accept the tos happy trucking(:
