wifi keeps turning off, then error
naterman1
Hello,
Hopefully someone can help. I have a moto droid 1 and my wifi keeps messing up. When I go into wifi to turn on, it will say "turning on" but then immediately say "turning off." It will continually do this over and over again until finally saying "error." Not really sure why or how to fix this, but it is pretty annoying that I can't use my wifi.
thanks
mine is doing the same thing except when i try to connect to my home router. every other router i connect to works fine, but when i get to my home one it will get to obtaining ip, then shut off, turn back on and try to obtain ip again.
i did the ssid thing people told me to enable but it already was so i really dont know what to do
error goes like this
Code:
<html>
<body>
<table>
<tr><td>06/23/2011 00:15:13</td><td> [WARNING] </td><td>sdiodrv_data_xfer_sync() transfer error! STAT = 0x108011</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [WARNING] </td><td>sdioDrv_WriteSync() FAILED!!</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [INFORMATION] </td><td>TIWLAN: 1986.896161: Try to SDBus Connect again...</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [WARNING] </td><td>wifi_set_power = 0</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [WARNING] </td><td>mapphone_wifi_power: 0</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [WARNING] </td><td>wifi_set_power = 1</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [WARNING] </td><td>mapphone_wifi_power: 1</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [INFORMATION] </td><td>TIWLAN SDIO sdioDrv_InitHw()!!SDIO clock Configuration is now set to 24Mhz</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [INFORMATION] </td><td>TIWLAN: 1987.055768: Try to SDBus Connect again...</td></tr>
<tr><td>06/23/2011 00:15:13</td><td> [INFORMATION] </td><td>TIWLAN: 1987.360364: Try to SDBus Connect again...</td></tr>
so... any ideas?
