So, I use wifi exclusively for data traffic (market, browser, what have ya), but if I look away from my phone, it goes to sleep, and I loose my wifi connection. Sometimes it'll connect on it's own when I wake it, sometimes I have to disable and enable wifi again to get it working again.
This is very annoying if you're downloading something, or if you use wifi and not cable to move files to and from your computer.
I've tried the WiFi always on apps, WiFi Locks, none of em works. The setting in advanced wifi settings is on Never, doesn't help. If I set the screen to not go off for a while, it'll work... till the screen goes off. But COME ON. Am I really supposed to have the screen on JUST so the wifi will continue to work?
Screen doesn't have to be on for cable usage ><
