Help Wifi not picking up when in range
KAuss
Not sure if any of you guys have the same problem but when I leave my Wifi on all day, and return home from work, my home Wifi never picks back up. When I toggle my Wifi on and off, it picks up again. My signal is always above 1 bar when on Wifi in my house, it just does NOT automatically connect anymore.
My sleep setting is always off too.
It never use to happen, then all of a sudden out of the blue I have to toggle Wifi just to connect.
When something is not working all of a sudden it is a problem. If you enjoy the side effects then probably not.
I am having the same problem and I do not know how to correct it. Wifi radio is on and set to never sleep. SSID says it's out of range even standing right next to my router. After I cycle Wifi off-on, it connects fine. Any help?
Did you try restarting the access point? Sometimes that helps. If it really bothers you, try something like Y5 or Auto Wifi Toggle from the market.
I just started to notice this as well. Did anyone find any updates. It is pretty annoying when something that has been working stops all of a sudden.
Basically wifi does not reconnect. I need to toggle wifi on/off and I have it set to never sleep. I am stock, rooted.
