Root Wifi not working on stock .602
darkcyber
Android Expert
Ok, I have done a complete brand new sbf to .602 running complete stock and for some reason I cannot get my wifi to work. It will try to connect and then disconnect, never connecting. Is anyone else having an issue on stock .602?
Wifi worked on .602 Sensei...so I am confused. Wiped the dalvik cache and cache and still no workyie :confused:
I had issues with WiFi as well. I just switched routers (due to new provider) and the new one was having all kinds of issues. Then, oddly, all I did was rename my network and it started working fine again. Weird. But when I am in a new place and try to connect, I get the same issue...Connecting...Disconnected...repeat. Stupid phone is starting to annoy me.
Never had a wifi issue before. Strange that wifi works in both.602 Sensei and CM7GB and not in plain stock .602.
Ok, figured out the wifi is working on stock .602. I went to my office this morning and tried it and it works fine. For some reason, it has decided to stop working at my house. I've tinkered with the router and changed password and the like on my router and still can't connect.
But anyway, it seems not to be a problem with gb, but rather my home router.
Has anything change at your home router (router name, mac address, etc.)?
