Root WiFi Not Working?
izander
Member
Hey guys, for some reason my WiFi won't work, the toggle says "turning on" and it never comes on, I'm not new to flashing ROMs, although I am new to HTC, and I had perfect WiFi with the Sense 4 ROM, but I flashed the MIUI ROM by Mobster and ever since then it hasn't worked, I'm on Midnight ROM right now and its having the same symptoms which is making me believe I did something stupid and its not the devs fault lol.
I am using TWRP 1.1 and I cleared everything, the cache, dalvik, and then formatted the system.
I could probably try reverting to a NANdroid backup from a while ago that I have, but I'd rather see if there is an easier solution.
of course I've tried reboots/reflashing.
Any questions or suggestions feel free!
Try wiping everything twice, then flashing the stock rom. If that doesn't work, try restoring your backup after what I told you to do.
