Root WIFI not working
D0VeR
Hey now!
Anybody know how to fix broken wifi?
Been broken for about a month now i think, havent had time to dig into it.
Try to turn it on, and it reads "error"
Running ZVE with Ldrifta rom #2 3.0.1
No addons or mods
Tried redownload and install a while ago
Yes, i wiped front to back as well.
Any help would be appreciated. Always had 4G until the tbag mobile bullshizer, now 3g all the time. starting to miss my wifi.
Thanx
its is for sure you do have to do the lg update,and take it to metro corporate store,they have a update as while,i had to go the other day to get it done,now afterwards my fone was doing good,but back to lagging,reboots etc,i just got this replacement phone from asurion in april,so i called asurion to explain,and one rep said that i still had 8months of warranty and they would ship me anew one free and should b here today,then they transffered me to there it and they stated they were going to email me the warranty i have left,to take it and the fone bk to metro to see if they could fix it,im debating if i want to go threw all that,and i stayed stock for the day since metro updated,so it seemd metros update is causing issues,i was told a new esteem is coming with icecream on it,but its not called esteem,something like lg optimus or something,oh by the way wen metro does the update they warn you it will erase everything,plus i took out my ex sd card too,but nothing was erased ,guess ill go ahead and go see wat kind of run around i get from them,will post the out come,home they gv me a new version lol wishful thinking,ill have my nexus with me so any questions u guys want me to ask just post them,by the waty can you take the wifi file,apk,odex, and exchange them with your broken one,just a question,i sure in hell dnt know as much as you!!! prob was a dumb ? but just thought i would see if it would work,have you tryied the lg.com updater,which it will say ur up to date but under the options there is a upgrade recovery ,i tried it just to see wat happens took bout 45 mins or so,give it a try,keep me up to par,sorry so long just trying to explain everything ive bn going threw,now must take phone bk lol
Wifi worked fine after i lg updated to zve
Problen started a week later
Dont know what triggered it.
Anyone know where the recent connection list is located?
Bought new router at the house
Old router ssid was For_Example
New router ssid is for_example
Maybe bug due to ssid with same charecters but different orientation?
If everything else is working i would do a wipe to data and reset it this should fix the wifi issue . If not maybe you need to just go to the lg site and do a update recovery . .
All fixed!
And im kinda pissed off at myself.
Tried everything.
Wipes
Flashes
Redownloads
Erase recent connections
Everything!
Except......
Pull battery!
Yay!
Weeks of this crap and i thought it would be something complicated!
Daaaaah!
I suck at this.. haha
Thats why i got out of the business
Thanks for the help peoples!
