Help WiFi Passwords
Hello..I am a new Thrill user and have a question. When I go into settings WiFi I get a list of networks available. When I try to connect the phone asks for a password. How do I get the keyboard to come up so I can enter the password???
Thanks....Phil
You should be able to just tap on one of the wifi networks and ill ask you to connect. From there enter your password.
Thanks....Phil
once you have selected a network to connect to it will give you a text entry box. press inside of that box to get the keyboard to pop up.
on some devices (mainly HTC) you can long press the "menu" key and the keyboard will pop up on any screen.
