Wifi problem after update
spridell
I have notticed that after the update my wifi will turn off and it will go over to 3G radio every so often.
My wifi is turned on but for some reason the phone will use the 3G radio instead of the wifi. The only way to fix it is to turn the wifi on and off.
Anyone else?
Update:
I have been able to somewhat replicate the problem.
I made 5 test calls, 3 of them the wifi came back on after the call was ended, on the other 2 calls the wifi radio never came on after the call was over. The 3G radio stayed on and i had to manualy turn on and off the wifi again.
