wifi problem big style
TOWBOR
Hi all
I am having real problems getting wifi, I have put in the correct password
and I still cant connect. any ideas very welcome.
Have you just updated to 2.3.3? There have been issues with WiFi in that update which are fixed to a certain extent by assigning yourself a static IP address.
HTC have admitted there was a bug in the latest 2.3.3 update, I think it only affects certain routers though as I can connect fine to my home and work one, which is lucky, but like El Presidente said, assign yourself a static IP address and it will usually fix most issues. I'm not sure if they are going to release a small update to fix this issue or not.
A friend of mines wireless router intermittently only allows one WiFi connection at a time (or 1 HTC WiFi device to be connected at a time) which is bizarre and does not happen all the time, so yeah, I'd do what Landovr said and restart your router.
I'm running RUU_Ace_Gingerbread_S_HTC_WWE_2.36.405.8_R_Radio_12.54.60.25_26.09.04.11_M2_release_187331_signed without a single WiFi issue. So the 2.3.3 WiFi issue does NOT effect everyone.
Cheers,
Sombre.
