Help Wifi Problem- I gt error when i try to connect
kcsh91
someone experienced tis too? any solutions? i wonder why will tis happen, it is strange, it sometimes managed to connect well n easily, but sometimes, it shown ERROR. ARGH! i found tis problem lately, after the system update, the latest update, as i seldom using Wifi while i was having exam week, so i couldnt knw if the updates do bring this. anyone can help? or any suggestions? i wish tis wont b the hardware problem, n will hav me for warranty, just bought it nt long T.T
Go to advanced settings in wifi settings... put in the values(dns, gateway..etc) manually..it will work
Hope it helps :)
Hope it helps :)
hmm, hw? like, i m going to restaurant, i wish to connect the WiFi, but i dun knw those details, the values u meant. any exact solutions? reali drive me crazy. =( once the update, i found tis problem, annoying.
what error are r u getting?
hmm, when i try to connect, the message "turning on" are shown, then after a while, i gt ERROR. did factory reset, restarted for many times. what should i do? after the recent update, the problem came. i just bought nt long, b4 the update, all are in well condition. what should i do? someone? reali love tis phone =( the worst solution, or mayb should i take it to the store n ask them to fix it? is it advisable to bring it to the store, as i scare they will make it even worser, as wad i had experienced with my other phones.
Are you connecting using your browser or just expecting to be able to search for a wi-fi network to download your emails or use the wi-fi connection in a specific application?
My experience is that many open and free wi-fi networks require you to register, and this can only be done via a browser. So trying to connect via any other application might well end up in an error unless you have used your browser to register yourself on the wi-fi network first.
John, no, the wireless networks i tried to connect are all open and free for all networks, nid no browser login in order to use the internet access. wad i mean here is, i try to turn on my WiFi in order to connect to networks, but it shown error instead of turned on successfully.
