lonelykitten91
Hi everyone!
I'll try my best to explain what the issue is as my level of expertise when it comes to tech stuff is not advanced.
I have uTorrent installed on my Xiaomi Device.
My internet works fine. I have VDSL plan 20 Mbps.
Whenever I download a uTorrent file on my Xiaomi device, it works ok, the download speed is ok. It reaches 2.5 MBps, just the right download speed for my VDSL plan.
However, I have 1 other device (Samsung Phone)
When I try to go to the internet with this Samsung device, it still detects the wifi signal, but it gives me an error saying my connection has timed out, and that little exclamation mark thing on the wifi symbol appears. When I go to youtube for instance, my Samsung device tells me I'm offline. Now when I look at my Xiaomi device, the download is still running.
Whenever I stop the uTorrent app, the internet comes back in my Samsung device. So I was able to rule out that the problem is the uTorrent. However, this never happened before. My modem router just got replaced as upgraded my ISP's plan. Before, I download things on the internet with no problem at all.
What I did so far?
I adjusted uTorrent's maximum download limit to just 500 KBps, as I was thinking that if I set it to Maximum, it will consume my bandwidth. But no, this didn't work. I was still getting the same trouble.
Hoping you guys can help me. Thank you so much!
What I did so far?
