Help wifi problem
asmatik
i have a wifi issue on my dhd, i accidentally tap the "forget" button on one of my wireless network.. can i reverse this action? i mean is there a method which i can use to discover that lost network? i tried to enter it manually, but no success.. somebody help me pls
You just need to enter the password etc again, there is no way for you to un-forget the network info.
When you get into the networks range, just open the wireless settings and enter the info again.
sir, the problem is that my DHD cannot detect the said network and when i try to enter it manually they only ask for the networks ssid and security which is none (open network)..
And the network is def broadcasting/accepting new connections?
I've had a play about with my settings at home and all I appear to need to connect is the SSID & password?
