Help wifi problems
I have the Asus me180 8" tablet, when I connect to home wifi it caused other devices to drop connection then shortly after the tablet will also loose connection, help yes.
Any error messages? Have you changed anything in your router since it came out of the box? Make and model of the router?
Thanks for response, my router is older model Linksys, I have used this a long time with never a problem. I use a Motorola Xoom, Ipad mini, Samsung netbook and two desktops all on this same wifi with no problems along with many friends who access my wifi when visiting, never had a problem until using the Asus Memo 8. I'm convinced that the problem is the Asus tablet. Also when I power down the new tablet everything else goes back to working just fine.
an update to this problem, I exchanged the Asus memo 8 for another and still have the problem. I turn this off and everything on my wifi works great with no problem, only when the Asus on is there a problem, looks like the answer is don't buy Asus.
