Wut's up everybody!!! First post here, but I've been follow'n ever since the GN got leaked. By far my fav android site
Just had a quick question about setting up my wifi at home.
I've run into the same issue others have, which is that my GN won't connect to my wireless router, instead, saying that there was an "authentication problem."
Went into the "Modify network" option, then "advanced options." Set "Proxy settings" to Manual.
There's only one field I don't really know what to put in. I have the "Proxy hostname," and the "Proxy port," but I have no clue what to put in the "Bypass proxy for" field.
I've tried to search what it's asking for, and everything that comes up is "how to bypass proxy."
Any help would be appreciated, as I really want to just run on my wifi connection at home and save a lil battery
