Help Wifi Question
Booya
I'm trying to upload a video to youtube via wifi. I have wifi turned on and connected to a router but the phone saying it still waiting for wifi. My question is do I have to turn off 3G for it to recognize the wifi? How do I know if I'm using wifi instead of 3G?
The wifi should kick in automatically if you have it enabled. You should also see the little wireless icon in the status bar when you are using wifi.
Is the wireless connection secured?
I think I know exactly what you're talking about. I just tried uploading my first video to youtube and I'm having the same issue. Wifi works and begins uploading, makes 4-5% progress then disconnects for whatever reason. This is when you'll see the waiting for wifi. Mine then reconnects a minute or two later and uploads another 4 or 5%.
VERY slow.. not sure what the cause is yet. I'll update when I know more.
Damn.. I definitely have a Wireless N router. Thanks jreed! Looks like we'll have to live with it until an update or fix.
Yes it is. I have a DLink G router. I bought the switcherpro widget. Turned off 3G through that and turned on wifi. The video uploaded to youtube. Very weird.
It might be the n protocol as others have mentioned.
I'm using Verizon's FIOS wireless router/modem (I think it does n too) and have not had any issues with both of the Droid X's that we have. Then again, the Mrs. was using the 3G for a while at home since she didn't know what the wireless toggle did. :eek:
I do notice that my wifi icon disappears from the status bar but then comes back after unlocking the phone.
that might be in part to battery settings
