Help Wifi Resetting
eulerphi8
I have been running the 2.3.15 leak and have noticed that the wifi resets itself sometimes. For example, I'll be listening to internet radio and then it'll stop suddenly. I'll look at my setting and basically wifi turns itself off and then immediately back on and reconnects to the network all by itself. I'm not moving or anything, it just seems like every once in a while the wifi turns itself off and on. Does anyone else notice this? I didn't have this problem with previous builds.
I had a similar problem after the update using an Airlink 101 router. Completely fixed when I upgraded the router's firmware.
