Right off the top of my head, I'd ask if they were both on the same network. Maybe one slipped to another unprotected signal. Has you done anything to the Note, such as flashing?
My wifi is working fine for T-Mo USA version.
- Have you rebooted your router since the Note has joined the network?
- Have you tried with the router's security disabled?
- Are the speed tests testing to the same test location?
Why is there a ? on the wifi indicator on the note? to me that indicates it was not connected.
Yes go in the system goto the wifi settings and uncheck the box that say for the system to notifies you of other open wifi near you it will go out when its unchecked
Ok, thanks.
Thanks to all your help guys but i think i've fixed it. i have changed the wireless network to b/g instead of b/g/n and now it seems to be loads faster on my newer devices.
Ok, thanks.
Ok, thanks.
I don't have the Note yet but will next Friday.
Where exactly do you change this setting at?
Heres mine
