Help wifi speeds
Upto what speed is wireless n supported on this device.
My router is set to run at speeds upto 300 Mbps but on the mobile the connection only ever appears to run at 65 Mbps?
Depending on your internet provider you could be capped out at 65mbps, which might i say is pretty much enough for any needs that you are trying to meet.
If you are unsatisfied i would suggest to call up your internet provider and look into the speeds you should be achieving.
Its not the internet link, which is 20 Meg, its what the wireless is connecting at. With my laptop I can connect at 300 Mbps but on the mobile it shows as 65 Mbps.
The extra speed is useful as I have a NAS as well and do transfer files to and from that....
