I have a fairly simple problem that may be more a router issue, but I'm not sure.
I have all the devices on my home network set to static IPs, my Incredible included. Almost daily, something will cause my phone to lose internet connectivity. I look on my router, and the static IP for my Incredible has magically changed. For example, I have it set to 127.168.0.11. When it stops working, I check the router settings and for some reason it shows 55.0.0.111.
I have noticed that the droid wifi problems sometimes start when I turn on a laptop or xbox and it attempts to connect to the network. Anyways, just curious if anyone else has seen this happen with their phone. The router is a D-Link 624.
Thanks in advance.
Thanks in advance.
. I'm using the standard 192.x.x.x.
