motionxxusxx
What are your thoughts on wifi strength? Im having an issue maintaining a connection in my room where my iphone 4 always maintained a solid connection.
>Settings >Battery Manager >Battery Profile Options
Actually you go to >Settings >Wireless & networks >Wi-Fi settings then hit the menu button and choose Advance then Wi-Fi sleep policy.
True, however the Battery Profile settings could still be causing conflicts.
The Battery Profile sets the "specific time period" (phone's idle time) for data connection disconnect, as well as when and how to put the phone into power saving mode. It does not manage "synchronization schedule".
"Synch Schedule" as it pertains to "when to connect to internet to synch accounts". The Battery Profile does "not" manage that process.
My point is that the Battery profile "stops all data", regardless of connection (WiFi/3G), after a fixed interval...including page loads (stuck status, data streams, etc.). Understood that there is a "WiFi sleep policy" however you still have to take the "system sleep policy" in consideration.
No, this is another setting to check, in case the user is still having disconnect issues, after determining WiFi sleep settings as "non-factor". "Maximum battery" is not the only condition that will disconnect data after 15 minutes.
Unfortuantely my wifi is in a part of the house that I can not move. My other phones maintain a wifi signal on the other side of the house while the atrix keeps losing connection in the middle of browsing. The wifi is fine when closer to my router it just does not have the same range as my other phones.
What kind of connection is it..B, G, N? Have you tried changing it, or disabling security (for proof of concept)?
If this isn't an issue for most of us then I would suspect its your router and or bad phone.
