moved your post here as it may be the same issues here.
try to "forget network" on your handset. then re scan for it.
try again.
did you leave the battery out for at least 2 minutes?
are you rooted? (didnt answer that one.
try again.
), but DLNA (Digital Living Network Alliance) is simply a method of all (so equipped) multi-media devices the ability to connect to each other (play music from your phone to stereo, or movie to your TV). Having it enabled isn't going to increase your exposure to malicious entities (significantly, anyway).
