Help wifi switches itself off
jlawjlaw1
severe wifi problem:
i switch on the WiFi and it switches itself off after approximately 30 seconds
have downloaded an applicaton called "fix wifi" but to no avail
thanks
You might want to check menu>settings>power saving mode and see if you have enabled turning off wifi when not connected to mobile AP. If you are running any other power saving apps, you might be running into a conflict.
