Help wifi tether app help
EPDP99
I have wifi tether app installed but when I open and run it it constantly acts like it looses 3g connection. computer will connect with local access only. phone will have 3g logo and will switch between up and down arrows then have both then none then the 3g logo will dissapear. it acts like it is constantly switching between channel/signals but never stays connected. I am on a rooted 2.3.4 using downgrade and s-off running stock+ rom. I had wifi tether working in the past after root and rom but now it doesnt. my wife is on a rooted 2.2 with no issues. we have same settings and radios and hers works fine. I have used tb to uninstall and restore older versions I have uninstalled and downloaded the newest apk version I could find and it still does the same thing. The phone has no issues connecting to other wifi hotspots(home or public) and work fine on its own data for internet surfing. the only problem Im having is with wifi tether to connect laptop to.
radio is 2.15.00.07.28
software 4.08.605.2
any ideas or different free rooted apps?
routing fix button checked appears to fix it this time. currently using laptop on wifi. we will see how long it lasts this time.
I will keep open garden in mind!
