How is this supposed to work?
I assume you start the app and then it would show up as a wireless network?
I don't see it listed as one from my laptop.
I tried pre 8 and 9.
Yep, done that and not seeing it.Once you're in the app you have to tap the center image for start the tether. Once the tether is up and running then you should see a wireless connection called Android Tether.
How do i change the name from Android tether to something else and also how do i set a passcode so no one i'm not aware can jump on it. Thanks
This worked for me. Version pre11 didn't connect at all with my xp run laptop but it works only has a problem when using a login for the account.
