Root WiFi Tether not working
I rooted my phone so that I could use tether. Rooting was a success but the wireless tether app isn't working.
Any help?
Sent from my HTCEVODesign4G using Tapatalk 2
you may have to go in to wifi settings and change setup-method to adhoc make sure that MSS Clamping is checked and Routing fix that should work it worked for me and many others try that and see if that will work
I'm using the Wireless Tether app. My computer shows that it is connected but it says that there is no Internet. uploadfromtaptalk1358591234457.jpg
I don't see those options.
I just realized I was using a different app. I was using "wireless Tether" you two were referring to "WiFi tether". Going to try again.
