jacobbrandon19
Member
When I connect to my wifi tether my computer tells me I have limited connectivity. When I show log it shows me that the wifi drivers failed to load. Anyone got this working for the prevail?
After reading what you linked I just changed the channel to channel 6 and it works. Thank you very much.
I also changed the soft-tap settings, changes to Channel 6 and I'm still having the wifi driver error message showing. Any suggestions?
I am having the same problem as well.
No errors are shown when loading wifi tether. My KF will show that it is connected but nothing can load.
Su
getprop|grep dns
Open terminal and do
It will spit out your dns. Set the dns in the wifi app to match the ones shown in terminal.Code:Su getprop|grep dns
Huh I use wi-fi tether (from the playstore) everyday for laptop and my kindle fire and it works fine, go figure
I get the wifi driver error still but it works for tethering the laptop. Speeds of .5MBps-1.2MBps.
