Help wifi tether
Antrax
Hi:
I'm trying to WiFi tether him my Evo and no matter what I do I keep getting a error code 67. I used unreboke and WiFi tether and no go, it shows the same error. Then tried easy tether and the same error. Tried quick setup without any change. I can use the browser whither the cell phone. My computer connects to the Evo but no internet connection is found.
Can some one please help me?
Diego
Hi:
Diego
What wifi tether did you use? You can't just use sprint hotspot, if that's what you're doing. There are mods out there to disable authentication for wired tether, if you want, though. Assuming you haven't already tried this, use android wifi thether:
android-wifi-tether - Project Hosting on Google Code
I'm using Android WiFi Tether 2.0.2. Without any network connection. It connects to my computer but no network is available.
I changed the Android WiFi Tether to the latest version that came out today and it's working just fine. Thanks for the help.
