Root WiFi tether
Awesome! I spent 4 hrs yesterday trying to get this to work and tried 6 different apps. Funny thing is I never thought to check the setup mode after trying the generic ics/jb (wlan0)
hi everyone i am having a small problem with the wifi tether i have. i rooted the boost force today and installed the app it is version 3.1-beta14 as far as i know that is the best one out i could be wrong but it keeps shutting its self off every 5-10 minutes i cant figure out for the life of me why it keeps doing this can someone please help
ok i am not sure what i did but it is working like it should now i am wondering if it didnt like me running an app that streams at the same time as running the wifi tether :/ anyways it is working fine now but thank you for all who may have read this thank you all including team osiris
How I use thing setting
Are you asking or telling?
start wifi tether then press menu the select settings then select
Change Device Profile....Dev profile: Generic ICS/JB (wlan0)
then back out and select
Change Setup Method.....Setup method: Netd-Ndc (master)
backout and reboot
Wifi tether for root works great for me. Full infrastructure tether to my s2, pc and ps3.
I didnt touch any other settings.
Thanks for the response to this post. Worked like a charm on ZTE Force. Just had to change it to ZTE Blade as the device and it worked! I now have a very happy customer.
