Bstressfree
Member
Has anyone gotten Wi-Fi (or Bluetooth) tether working on this phone yet? Is it's hardware even capable of it?
Yeah after rooting my phone the first thing I did was WiFi tether. I was using WiFi tether with root.
Thanks! Those settings work for me. Although I get an error message when I start the wifi, I can still connect to it and use it. Wi-fi encryption and Access Control don't seem to work though, nor does changing the SSID name. No matter what I do it's still called AndroidTether.
Hey sorry it took me so long to get back in here, but I see that someone else already found that page with the tether apps. I see that you're having problems with it though. No one has mentioned WHICH of the apps they choose from the list? I installed the experimental one at the very top of the list and everything is working as it should for me. Notifications, access control, upload and download meters the whole shebang.Yes, I can't change the SSID, nor do my usage stats (upload/download) show up at the bottom of the main screen. Also, I don't always get a notification when a client connects (though the client usually shows up in the access log list). I have not tried access control or encryption.
Still, it is progress....because it does work otherwise.
..and yes, I forgot to mention that I used the JB/wlan0 setting like Josh did above.
That is all interesting but nobody telling anyone how to do anything.
Maybe it's in the settings?
Device profile- generic ICS/JB (wlan0)
Setup method- Auto
Set Netd Max Client Cmd-NOT checked
Enable wifi encryption-checked
I have changed SSID no prob
Mac addresses spoof-NOT checked
Don't disable Bluetooth-NOT checked
Wi-Fi driver reload-NOT checked
Wi-Fi driver reload 2-NOT checked
Enable access control- checked
Keep alive connection checking-checked
MSS CLAMPING- checked
Routing fix - NOT checked
Disable update check- CHECKED!
NEVER UPDATE SOMETHING THAT YOU'RE HAPPY WITH AS IT IS!
I would suggest that if you change your settings close the app and restart the phone before trying it out. May not matter but can't hurt either?
Hope this works for everyone else as well as it has for me
I feel the need to update as it addresses and fixes bugs.
Absolutely Joshua, but if you've got a buggy app you pretty much know it. All too often updates are based on a problem with a particular model of phone that have nothing to do with yours. At the very least you should watch reviews after an update is issued for a few days. Particularly reviews from the same model phone as yours.
With side loaded apps like our wifi app were not likely to have the advantage of checking reviews..sooo as long I'm happy with what I've got I'm not messin with it. To each his own tho.
You can install the stable version of Wifi Tether for Root Users on Google Play and check the reviews of the stable version.
Oddly enough, Wifi Tether may REQUIRE encryption. At least it did with mine. Tried the Wifi Tether version on Google Play as well as the 3.3 beta2 version and both versions refused to broadcast any signal, UNTIL I enabled encryption. Then it worked fine.
The only thing I might suggest is to give ver. 3.3 beta 2 a try. I've been using it for almost two weeks and so far only had one problem once when it somehow switched its LAN network setting from 192.168.1.xx to 192.168.2.xxx. But once I caught it and switched it back I haven't had any more problems.
If anyone is interested, I haven't rooted my Awe (yet), and I've tethered using FoxFi on the host device (my wife's not-rooted Awe).
