WIFI timer not working since 4.3 update
james_uk
When i was using 4.2.2 the wifi timer worked fine, i had it set to come on at a certain time and off, and it worked fine
Since updating to 4.3 i have set the same timer again (as i done a clean install of 4.3) and now every time it gets to the on time, i get a notification saying the wifi timer has started but the wifi it's self doesn't come on, when i look at my short cut tabs at the top the wifi one if off, even after the wifi timer says its started.
is this a known issue?
James
