Is their a way to cancel the option in the galaxy that it will not surf on a 3g network automatically when for some reason i lose my wifi signal for a sec?
Does not sound clear to me what is it actually you want? So do you want it to switch to 3G when WiFi connection is temporarily lost, or do you want it to try reconnecting to your WiFi instead of switching to 3G?
Okay, than your choice is as suggested to turn off 3G data with APNDroid or Toggle Data while you using WiFi and than re-enable it back when you're done.
