Help Wifi Widget Doesn't Always Work
Janitor
Has anyone else noticed that when they turn WiFi on through the widget (either android or motorola one) it doesn't always actually turn on wireless?
I usually have to go to WiFi settings and then once I do that it connects to my router. This will keep happening until I restart the phone and then the widget will work another 1-2 times and then I'll have to go into the settings menu until I restart again.
Unrelated: Has anyone else had their 3G dropout today or is it just me? I'm in the northeast.
I've had the same problem with the same resolution. Assume it's a bug, because as soon as you hit on the wi-fi settings, it connects.
From what I read change your wireless router settings to g instead of n. I was under the assumption that the last update was going to fix it, but it didnt.
