Help Wifi
I have a question, i have metropcs as my provider, when i try to startup my wifi on my phone at home i can log into Belkin_N_Wireless, and it says that metropcs wifi is not in range, why would that be ?
No idea... I deleted Metro Easy wifi, so I do not get that issue
Is that the default wifi? I'm constantly having to reconnect my wifi.
What do you use instead yankee? (get it...NY/Yankee kyuck kyuck):rolleyes:
You phone has a default wifi even after deleting MetroPCS Easy Wi-Fi, all Eeasy wifi does is ...well...it supposedly helps you connect to available wifi's quicker and easier...which in my opinion is kind of dumb....in my recent studies....when turning on your wifi...which is that little cone looking symbol..with the bars in it that appears right next to your signal IS YOUR MAIN WIFI....and then you get a little blue circle to the left which is the easy wifi....all it does IMO is drain your battery FASTER while using wifi...but in all honesty...your regular wifi does everything the easy wifi does as in remember your last connection you were on, and the pw....your default wifi already does that.... if you go to MCD lets say...they have wifi...all you need to do if turn your wifi on...then go into wifi settings, and select the MCD network and hit connect....easy wifi..basically does that FOR YOU making you not needing to do that extra step...which is dumb...why should I keep it when it just drains the battery....the simple extra step.. I can easily do in a extra 20 to 30 seconds....it's just dumb bloatware, and im glad i got rid of it.. there are tons of mixed opinions on this app, but when you sit and really break it down...all it does and save you 30 seconds while it kills ur battery....i rather manually search and connect to the hotspot I WANT.. not the hotspot...IT WANTS
