Help Wifi
I am having an issue with connecting the WIFI to my wireless router at home. It keeps saying error with WIFI. This is my first 4G, is it an issue with connecting to a WIFI with a 4G phone...
It shouldn't have any problems with 4G.
Did you try resetting the router? Sometimes it is the best fix. :D
Are you sure you put in the right information? Might want to double check that if you haven't.
It worked the first day and it has not ever since. Resetting the router doesn't help. Continues to say error whenever I select the wifi.
This is actually a pretty wide spread issue. Resetting your phone will only help for a little while.
I started a thread on LG's forums. If you like, you can post about it there. There are also links to threads on another site that may help you in that thread.
G2x wifi problems - LG Forum
