mjohnson3764
I always have the problem that I have my WiFi on at home to use my home internet. But then when I go ANYWHERE, and I'm using the internet, my phone will pick up random WiFi connections that don't connect properly while I'm using the internet. So then I have to disable WiFi and restart what I'm doing so it will connect using my Mobile Network again.
Is there a way to only allow your WiFi to connect to certain access points so it will not attempt to connect to any others. I would like to be able to always leave my WiFi set to on so it will seamlessly connect when I get home, or to work, or whatever saved access points I want to connect to.
Let me know if this is at all possible.
Thanks,
Mike
Thanks,
Mike
