When you are in range of the network go to System settings -> wifi -> choose the network and connect (wifi must be on). After that it will be remembered until you "forget the network"
Welcome to Android Forums, look around and enjoy. :beerglass:
Be sure to check out the sections dedicated to your Android device and your Carrier.
Also if you want to be able to connect to the Forums from your Android device, be sure to check out the free Phandroid app in the Google Play Market. Cheers!!!!
