Just wondered what everybodys thoughts are ? Im thinking of doing away with my Wildfire for something of similar standard, The Samsung Ace!
I just feel the Wildfire is so slow and laggy and i also hate texting on it.
Maybe someone might be able to recomend something else!!
Mate, straight away i would recommend Samsung Ace, because it has a 800MHz processor whereas the Wildfire has 528MHz
Ive listed 3 points which should be taken into consideration when getting a phone
Screen size and resolution:
Wildfire has a resolution of 240 X 320 QVGA and a screen size of 3.2 inches (
take it from someone who has a Wildfire, the resolution is crap which results in lower-quality images), Samsung Ace has 320 x 480 HVGA and 3.5 inches, Your Samsung will display better looking images with a bigger screen
Samsung Ace 1 - HTC Wildfire 0
Phone Memory
Wildfire has 175MB whereas Samsung Ace has 158MB, on Wildfire you can store more apps that you cant transfer to your SD card, (not really a major advantage but it does help to have 20MB more memory
Samsung Ace 1 - HTC Wildfire 1
Battery life
Samsung Ace has better battery life, more battery life equal more phone usage simple as
Samsung Ace 2 - HTC Wildfire 1
To rap that all up, DO NOT GET WILDFIRE
If you want other choices, what is your budget?
