Help Wildfire Installation Aborted! PLZ HELP!!!!!
Hi I Rooted My Phone And when i try installing a rom it says this
Finding update package...
Opening update package..
Installing update...
E:Error in /sdcard/DK_CUSTOM_ROM_V4.4-EDIFY.zip
(Status 6)
Installation aborted.
PLZ HELP ME!!!!:(:(
I WANT A CUSTOM ROM
Btw DK_CUSTOM_ROM_V4.4-EDIFY.zip is the custom rom
(Status 6)
PLZ HELP ME!!!!:(:(
I WANT A CUSTOM ROM
Ok im assuming that this has occurred in Clockwork Recovery??
What method did you use to root your Wildfire?
Maybe the problem might be with the ROM, try flashing a standard Wildpuzzle ROM, if it works then you know that, that ROM is faulty
[ROM][25/10] OLDWildPuzzleROM_2.2 Froyo v8.0.11 - xda-developers
