Help Wildfire LED light doesn't work after debranding
Hey guys I was if was wondering if you could me help with this problem.
I recently bought a Wildfire which was branded to T-Mobile , I first unbranded it to the stock ROM version 1.14 but that wouldn't let me update to 2.2, so I then installed the 2.2 ROM
My phone is working great now apart from the fact my LED does not switch on
I have used the camera, torchlight app and light widget and it shows me on screen that the light is on but it doesn't work :( :confused:
I would appreciate any help/advice at all and thanks in advance guys
Hi friend,
Has your problem been solved? I have the same problem my flashlight just works with photo camera but it doesn't work with flashlight app or video camera please let me know if you have find the reason
