wildfireboy
Hi,
I've had my Wildfire for just over a year and a half now and I haven't had any problems so far (apart from the usual of it getting slower over time).
About a week ago it started turning of randomly, it doesn't show "powering off" and then shuts down, the screen just goes blank and then the phone is off. This makes me think it isn't a battery problem. (It never seems to happen when the charger is connected but I don't have another battery to check it with though.)
It tends to happen when I'm using the phone (not when its just in my pocket) and usually when I'm doing something 'complicated' (like loading a webpage) rather than just sending texts (although it has happened with all data and GPS off).
I have tried reseting the phone (both from the settings menu and by pressing the volume-down and power button and then choosing clear storage). It didn't help, however, I see my call history is still there.
So 1) anyone had this problem? And any solutions?
2) anyone know how to completely reset the phone? Is there a reset pin that I can stick a pen in?
Thanks in advance!
Thanks in advance!
