WILDFIRE S amber flashing LED
hardav
My Wildfire S will not power up and will not go into hard reset, when connected to PC amber LED blinks and phone vibrates on each blink. Is this phone bricked?:
Try removing the battery and putting it back in. Let it charge for about 20 mins then remove the charger and try to turn it on...
Let me know if it doesn't work
edit: Charge it from the plug, it charges faster than on pc
Have you tried a different charger?
I had the same problem once: Just flashing light (But no vibrating) but it corrected itself. I didn't do anything. If nothing works, I would say just leave it 1 or 2 days without touching it and try charging it again...Who knows?
