If you can root your phone and install a custom rom you can get lots of free space.
Currently I'm running cm 9 on my wildfire s. I have 2 gb of internal storage. Its pretty easy to get this. You need a rooted device with a 8gb or more sd card. The sd card should also be a class 6 or higher. if you use a low class sd card your phone will lag like hell.
Create a partition(this is the new internal memory) on your sd card which is a ext filesystem.[I created a 2 gb partition]. Then go to the recovery and flash the data2sd script. Finally reboot.
There you go 2 gb of internal space!
Here's the link:
http://forum.xda-developers.com/showthread.php?t=1490607
