This often happens when the little clip that holds the simcard comes loose under the battery, however usually pressing it in place stops the problem, however this time it wont rectify it. Any ideas what's wrong?!?
Not sure why your sim is not working but I would try to maybe wipe the sim card with a cloth and just blow on the phone....
Hopefully that'll help ya
Otherwise see if you can put a different sim and see if you get the same problem. If you do I would say the problem is with the phone and not the sim card
