I was wondering if I root & S-off the Wildfire S, add/remove apps after it is rooted & s-offed, if I foul it up (assuming I don't brick the phone) when I am adding apps (which need root) will the factory reset still reset it to as it was when it first came out of the box?
Or, if I install one of the ROMS floating around and assuming it does not brick the phone, will factory reset put the original rom back in place/set it all back like it was when it first came out of the box?
It's a Virgin Mobile Wildfire S. Thanks!
