will i loose navigation app
elTJ
will i loose the navigation app if i update to gingerbread? it is the pre installed navigation app. i understand that i will loose all the other apps i have installed?
No you shouldn't since it is a stock app that came with your phone. You will only lose apps you installed, but they can be reloaded after a reset.
