Will I lose the recent update if I restore to stock settings?
dlee1001
After I got the maintenance update for this phone (UCKE3) with much difficulty, I have a new question:
If something on my Infuse goes horribly wrong (let's hope that doesn't happen though) and the only way to correct it is to restore back to factory settings (to stock), will I lose the UCKE3 update? Do you know whether I'd be back at UCKD5?
In case you don't know about the alphabet soup I'm serving here, you can read this for clarity: Samsung Infuse 4G Gets A Maintenance Update FROYO.UCKE3 [Download] - Gadgetian (NOTE: Despite part of the title saying "Download," there is no way to download the update to your phone or computer. The only way to do that is to use your phone's software update settings).
When you restore it should still have the update. That update is not even really needed though because it was just to fix syncing contacts to the phone through outlook. This update is not really needed for most people with this phone. Anyway, if it does restore the update, it probably replaces it anyway.
